Downloaded the CE version... seems a bit faster, which is good stuff.
Bentley View has the potential to reach a very wide audience... so I was a little disappointed to see the Clip Volume tool not being available. :-(
If the dgn has a DV then the DV's Clip volume is available. But, we need to realise that BV will be used as a 'swiss army knife' go-to tool to view all CAD formats. It opens a huge number of formats pretty well, but these days viewing 3d models is becoming increasingly common. If you accept this, than not having clipping tools to 'peel back' the 3d model to see what's inside is a critical got-to-have that any go-to tool will need to have.
The cut geometry etc is proxy graphics anyway that is volatile... should be compatible enough in read only mode? So near, yet... so far. Update 13?
The same goes for attaching Reference files. Mstn has already got all the functionality in place.
Hi Dominic. I totaly agree with you. Please let Dan Eng know, i think he might be the Bentley view product ovner.
Hi Dominic and helgeh,
We are currently investigating the possibility of making the Clip Volume tools available in a Read-Only file in Bentley View CONNECT Edition. We will keep you and everyone posted.
Daniel Eng
Thanks...
Hi Dan. That is good news! I hope also Dominics other sugestion about alowing referencing/ opening multiple files at the same is beeing considered for future update. This could also be read only.
Helge
Hi Dan
Any news at all on these things yet?
