Using Microstation V8i (SELECTseries 3): how can I change the right-click setting to take me to a properties or similar bar?
You should be able to right-click and hold. A popup menu will appear with lots of options including properties.
ORD - 2021 R1 10.10.1.3
ORD 2022 R1.1 - 10.11.3.2
ORD 2022 R3 - 10.12.2.4
ProjectWise - 10.0.3.453
As well as <crtl> right click will bring up the main menu where many properties can be changed.
