Please could some one let me have an update to the SR noted above. This was scheduled for Update 10 but obviously didn't make it as it is still an ongoing problem. This has been noted by Bentley as an important defect!
This SR relates to Defect 862239 which has been started and is currently scheduled to be in Update 13.
That's a shame as that could be 3-4 months away, especially as you noted this a a major bug.
This has still not been fixed in U13. I have just tried a model copy and all levels of the dwg reference where turned on and didn't match the original model. Why hasn't this been fixed?
Anyone from Bentley care to respond to this? Still not working in U13 even though you said it would be!!
Hello Stuart, I will contact you via Service Request, using the dataset provide via the SR this appears to be OK in Update 13 using No delivered Workspace/WorkSet. It may be down to configuration or perhaps another issue your seeing.
