There is a new way microstation connect creates offset lines in 3d. When I use Offset Solid Edges with loop tool, it would round some of the negative corners. I want all of the edges to be sharp as in v8i. Please help!
Defect 1009192 has been filed, Thanks for reporting.
This problem is still in Update 13, do we know when it will be fixed?
As an alternative try using the Extract Faces/Edges tool.
This is not a solution in long term. We used this method around 15 years ago in pre v8i version and it is time consuming comparing to offset. May I suggest to Bentley to play with sketchup ,which does the offset correctly and that’s where the tool originated from I believe. There is no point to have a tool which doesn’t follow the industry standard.
This is currently scheduled for Update 14 release.
