[MSV8i] Scaling objects in drawing from origin (0,0,0)
Good day everyone,
I need help in scaling a 3d drawing I received about the origin (0,0,0). In short, the objects in the file need to be scaled by 1.1 only in the x and y plane. Z plane to be left alone. I'm still fairly new to MicroStation and wasn't sure how to scale but help would be appreciative. Thanks
  • The scale tool setting have the option to "unlock" X, Y & Z from each other. This will let you scale by any X and/or Y scale you want while leaving Z scale equal to 1 (for no effect).
    To scale around the origin you will use the key-in window to enter XY=0,0,0 when prompted for the "origin point" (point to scale around).
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
    Answer Verified By: David Palacios
Reply
    MaryB
