i just made a parametric cell, it works well. The cell is a conveyor with power unit, but sometime i do not need power unit when placing the cell. Is there any way to delete elements in a cell automatically using variables, when placing cell in design model. i do not want explode cell and delete elements.
Hi Peter,
I would recommend you create two parametric cells, one has power unit, the other does not. There is no option to let user delete element when placing cell.
Grace
So you want to conditional show elements based on the state of a variable. Not necessarily delete them but to turn them off or hide them?
~HTH
John.
yep
not my question, but yes, I would like to be able to do this
visibility parameter like Revit.
Duncan, will this be available on the next update or has someone filed this as an enhancement? I’m also having this issue. It would be great if we can have a menu that lets us hide an element and assign a variable on it to turn it on/off
