The expression LookUP.GetEntry does not seem to be defined in the list of expressions. Are we supposed to create it? This looks potentially very useful but so far it's telling me that my expression isn't valid.
LookUp.GetEntry("Table Name", "Key Column Name", this.Key Column Value).Property Name
Hi Duncan,
The Lookup Table Expression is available as General Access Technology Preview feature in MicroStation Update 12 build. Please find attached pdf document for detailed help.
PDF
Also this web help for reference :
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v14/en/LookUp.html
Let me know if you need any thing.
Hi Snehal
I can't get this to work. Below is my test settings. What am I doing wrong?
I see all the things are done properly.
Now, add the A-100, A-200 one by one in the Number field and see that Title gets populated automatically from the Excel file as per value in Number field.
Let me know if this works.
Answer Verified By: Duncan Macdonald
Okay I have that working. How do I get the Number field to be a pick list as the example in the documentation?
1. You can create a new Pick List from Pick List Manager dialog.
2. Set Pick List to the Number field in definition dialog.
3. You can easily select PickList as you need while attaching items.
Please let me know if you need anything.
