Update after update MS CE keeps crashing when I try to open any dwgs with it. I wonder when this will be fixed. Until then, MS CE will be practically uselss for our company.... This problem gets more and more frustrating because V8i doesn't support ACAD 2018 format. Right now I am seriously considering shoud we dump Microscation for good and start using ACAD CIVIL 3D instead?
I see a Defect 755741 being logged for this issue. However we were not able to reproduce a crash at our end.
I tested your dataset "5744_Puolarmets__kartta.dwg, SunaPuolar.dwg" again and cannot reproduce a crash. I tried opening both the DWG file as the first file as you have mentioned in the Service Request and cannot reproduce a crash.
We may need some memory dumps. I will contact you via the Service Request.
