I have drawing titles set up with data fields. Color, level, font, etc are also preset. When i use the "Fill in Single Data Field" tool, the color of the text changes. How can I prevent this from happening? This has never been an issue with any other version of Microstation.
What version are you using now?
MaryB
Microstation Update 11 Version 10.11.00.36
to clarify, Microstation Connect Edition Update 11 Version 10.11.00.36
Hopefully someone more knowledgeable in Connect will be along soon to help. I haven't been able to do more than play with it a little bit.
Hi, This is Defect 940664 and is one of the many issues why our office can't switch to Microstation Connect.
The rumor is that it is scheduled to be fixed in Update 13...
--Robert
