The File dialog speed problems seems to be back. 20s+ for it to show up. Even on the second and third try.
It seems to be fine on my computer ... but I guess it just because of I have another workspace and right now not plenty of design files on mapped network drive. So I am open to believe it's really bug regression :-(
Jan
I am not seeing this issue with our networked configuration either.
~HTH
John.
yep
This may be related to the type of elements contained within your design file or even the configuration settings within your workspace. Maybe you could start with an example design file for testing or maybe logging this directly to Bentley support in a Service Request.
Andrew Bell said:configuration settings
Yes. I did not have a Workspace set. When I selected one, the Open Dialog was back to normal. Hopefully, this is a small tweak for later. In the meantime, a note in the Help file would be helpful?
Spoke too soon. Slow dialog is back.
