I have been having problems with clocking after changing draping distance parameters and / or any command that requires a key in. Lately, I have noticed that if I mouse click out of the program to my windows 10 desktop then click back into the program it will resolve the clocking issue and continue through the command. This happens continually and limits the amount of work I can get done.
Has anybody had these problems and if so have you found a solution?
Martin McDowell said:I have been having problems with clocking
Please explain what you mean by 'clocking'.
Also, what is TOPODOT? There's a product called TopDOT from C3D.
Martin McDowell said: I mouse click out of the program to my windows 10 desktop
What version (e.g. v8.11.x.y) of MicroStation are you using?
Maybe try disabling window ghosting with the MS_DISABLEWINDOWGHOSTING variable?
communities.bentley.com/.../preventing-not-responding-message
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hi Martin,
You can contact us at support@topodot.com if you have any problems with TopoDOT. We do not typically monitor this area of the Bentley forums.
Once you contact the support team, one of us will setup a web meeting so that we can better understand the problem you are having.
Thank you Maury!
