When I open my Configuration : User - I am unable to change the default design file seed. The options are grayed out and there is an L after the word System
See Example:
Jon, this information did the trick
I was able to change:
Into the following:Now everytime I select new if my .ucf is loaded it goes to the one I had wanted. Thank you so very much for your help through the years
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
