This may be simple or hard, most markup I get I normally want to check what the Working Units are set on and the Active Scale.
I know how to open and hit w for working or A twice to get to Active Angle or even S and get to snaps. But I was hoping to
Key-in something and (Settings>Design File>Working Units.
try MDL LOAD DGNSET ( FYI it came from the help menu)
works but I cant find any further settings to make it work, but if I used the working units once msnt remembers so next time I use MDL LOAD DGNSET the working units is already been selected and I can see the working units
Lorys
When I can find the file above I will try it, I sed browse but still did not see it ?
Version: MicroStation V8i SS 10
RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
oh, sorry Key-in MDL LOAD DGNSET, it worked can a person go one step further and add active scale and just go straight
there
wouldn't it just be
AS=1;MDL LOAD DGNSET
Looked good, but I set it on Grid, went to Key in and followed the example, it still came up on Grid. If you go to a setting and then click OK next time you open Settings>Design File, It will open to the last ok, )c;
