Hi All,
I have set MS_REF_NEWLEVELDISPLAY = 1 within my standards.cfg
However I am pretty sure this does not seem to work all the time.
Is this a know issue?
This is in AECOsim CEU4 (equivalent to Microstation CEU11)
Don't work, Override doesn't work but sometimes. I've been fighting this for years. No good work around. I put all my stuff in one design model, create lots of sheets in same file. Variable, setting the reference to Never does not work. Plus it's not consistent, works some times. I've had this issue since v8i, drives me nuts as I'm always having to create new levels after I set up the sheets. If you can have every single level created ahead of time or your sheets reference a different DGN, you'll be O.K.
If MS_REF_NEWLEVELDISPLAY=1 would do what it says, I'd be really happy.
I came up with a script ( with a little help) that only works in batch processor but will apply an new override to an existing ref attachment I havent tested it with nested as for nested I just go to the nest and change the override there and it always works in the drg that nest is attached to..
But lots of drawings that were single depth not nested with the same ref and boss want to change the symbology of something in all drgs that in a dgnlib has always driven me nuts since V8i could handle dgnlibs... I can do it one at a time in each drg with overrides but that is so time wasteful .. why I developed with help the script ... here it is with instructional comments copy and paste into your batch processor and save it s you can even use it on single file or several...
not tested with sheet models --- enjoy and feel free to share around
BTW Mary I would like to know it it works as intended for you too
as it works great for me..
Lorys
Thanks all for the response.
Good to know it wasn't just me going a bit loopy.
It is a little annoying that the variable doesn't work consistently, but not such major prob at moment. I am in process of moving us from SS to CE and hadn't noticed it as such an issue before with our old configs but i cannot be too sure now.
Lorys, when I get 'round to it, will give your script a go. Thanks heaps.
Cheers
AECOsim SS6 + CONNECT U4, Windows 7 Pro, 64Bit, Intel Xeon E3-1275 v5 @ 3.6GHz, 32GB RAM, NVIDIA Quadro P1000
I'm using ss3 and 4 and its a big head too but it is consistant, which lead me to create the script and batch processor
It does work for me, Lorys. Thank you!
MaryB
only took 8 years to finally figure it out this year with some help from fellow poster in another forum...
What about a vote for my hard work and desire to share with my msnt brothers and sisters
