Hi I am trying to export/translate from DGN to SHP using FME but the translation picks up two lines of text in MS as a text node and exports the node number instead of the actual text. How can I convert the text in MS back to one line in bulk. If you use 'drop' it makes it into 2 separate lines. I am using V8i Select Series 2 (08.11.07.443)
Thanks.
What's FME?
MaryB
Hi The Feature Manipulation Engine (FME) is a platform that streamlines the translation of spatial data between geometric and digital formats. I use it for moving from DGN to SHP files and back.
Microstation V8i is what we are currently using.
g00ner said:I am trying to export/translate from DGN to SHP using FME but the translation picks up two lines of text in MS as a text node and exports the node number instead of the actual text
Isn't that a question for FME rather than this Forum?
You might like also to move your question to the Desktop Mapping Forum: the GIS users are more familiar with FME than those of us in this MicroStation Forum.
g00ner said:How can I convert the text in MS back to one line in bulk?
I think you'll need a VBA macro to achieve that.
