HI,
I am using Microstation CONNECT and want to change the presentation of a Point Cloud to Elevation however this is no longer an option in the Point Cloud dialogue box. Where is this option? Has it been removed in the CONNECT version???
Lee
Isn't this an option of the view attributes window or the new display styles?
Frank
It is indeed. I'd never noticed in the attribute window before. Thanks Frank!
Do you mean the colorization option in the point cloud presentation?
That is still in the product please see:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v14/en/GUID-9EEB3812-DA68-5E8F-E4AE-4A4A2BE8CB91.html
