As the title. There is no data in the report when I attempt to preview but placing it as a table works. Here is my report
Here is the preview
Here is the table
Which works as expected.
Duncan Macdonald said:There is no data in the report when I attempt to preview but placing it as a table works
I wrote some example Reports to demonstrate that they work with DGN elements, and don't require Item Types. This Report on Areas is similar to yours.
Can you share your files for review?
if so please use the following link:
bentley.sharefile.com/r-r45fd73404dc42a9a
test7.dgn
I've attached it here. It's only a test file.
Duncan Macdonald said:test7.dgn
Change your Report definition Search Location to All (not Current Selection).
Neither By Fence nor Current Selection seem to work. That begs the question: Why does MicroStation create a Table when the Report is empty?
Answer Verified By: Duncan Macdonald
Thanks Jon. That works, however I would have thought that if I have elements selected then the report should preview when set to selection or fence (if I have one defined).
