is there a way to skip problem or "bad" files that CE cannot open/load during the opening process of master file? I have a DGN file with about 20 mixed DGN/DWG files attached, which opens fine on one machine with CE10, but fails on another one with same CE10 (both using same configuration) and opens fine in SS4
or open file without ref files at all?
thanks
For others not familiar with the command line switches please see:
https://communities.bentley.com/products/microstation/w/microstation__wiki/8873/microstation-command-line-options-and-switches
