I want to create a Workset with the information shown below.
Has anyone done this?
Are you talking about the WorkSet.Template? How would that set up the folders and files I need?
Brian MacCartney
Senior Designer, Electrical
using the dialog to create the subfolders will not get you the directory structure you are looking for. However - you can manually create the directory structure or use an already existing project/workset as a template. It will use the existing directory structure and files (if needed). This is the template option in the workset creation. If "none" is selected in the template choice, then the workset.template.cfg is used but again it limits how/where the folders get created.
Timothy Hickman
Main: 877 627 3772|
I have done this but cannot seem to get it to create a new project folder from the existing template. It creates the CFG and Dwngs files in the WorkSet folder on my "C" drive but does not create the folder on the Server where I have directed it.
Oh that's a bug. I have a defect filed on it. It seems it really doesn't like to do things outside the Bentley defined directories. I believe it won't create things other than to the location that _USTN_WorkSETsRoot is defined.
~HTH
John.
yep
