Hi everybody, I use microstation V8i SS4. I want polyline have all corners draw SHARP, but the angle is less than 30 degrees, not SHARP. Help me sharpen the corners.Thank you very much.Sorry, my english bad
Hi Vu,
What kind of line style are you using? do you have the same problem with one of the Line Styles delivered by Bentley? I see you are using 005.
also, did you try using the Modify element tool?
Maria Garcia
I tried it, but the problem was not resolved. If you setup Vectex type is Rounded, then angle is less than 30 degrees, not Rounded.
In your screenshot, SmarLine joints are not bad as shown. Joints are open while placement, but chamfers properly after placement (See my screenshot). If you want sharp corners you can use MutiLine tool. Sharp joints for SmartLine will unnecessary occupy more geometry space as shown in my screenshot. Any ways, I can file an Enhancement for this but possibilities of getting WAD
Thanks for reporting,
Manoj
Please reduce Rounding Radius or place long length of smartline which can accommodate a radius of 100.
HTH,
Thanks for the help, however, my work requires all corners to be sharp. Do you know how to change this setting? because if the angle is less than 30 degrees, the angle will not be sharp
When the angle is more than 30 degrees
when the angle is less than 30 degrees
Thank you all for helping me !
