In v8i there is a wonderful tool to synchronize different live views. In Connect i'm only seeing sync view with google earth. Did the ability to sync live views get removed? If not, how does it work in Connect? Thanks.
JSackett said:In v8i there is a wonderful tool to synchronize different live views.
as far as I remember, V8i has not provided such functionality. but there where were some tools from 3rd party developers.
JSackett said:If not, how does it work in Connect?
Can you provide details what MDL application / utility you use to synchronize the views?
V8i application are not compatible with CONNECT Edition (because V8i is 32bit and CE is 64bit app) and the application code has to be modified and recompiled. To know what application you use can help to e.g. contat its author.
With regards,
Jan
Are you able to give a little more detail into the v8i tool that you used? Where was it located on the menus, what was the key in, what did it synchronize, etc all would help.
~HTH
John.
yep
