Dear Experts,
My question is very straight forward. I need standalone/offline installer for Miscrostation Connect Edition. We are having poor internet connection now a days so it is taking forever to install Microstation C.Edtion for 300+ users.
Kindly support.
Antash
You can build a local deployment of MicroStation by running the exe with the /layout switch. This will download everything local and set it up so it can be silently installed to the machines if you so desire.
This wiki may help.
communities.bentley.com/.../microstation-connect---how-to-create-a-deployment-image
~HTH
John.
yep
Create a Deployment Image once and then use it to install on all the machines. Refer to this Wiki.
