In Connect U12 the group hole command doesn't seem to be working. I select the boundary and then the first hole then when I try and hold down Ctrl and pick the next hole it doesn't allow me to select anything.
Hi Duncan,
Duncan Macdonald said:I select the boundary and then the first hole then when I try and hold down Ctrl and pick the next hole it doesn't allow me to select anything.
I works fine with my CE U12 installation.
Alternatively you can select (add to Selection set) all elements that your want to group upfront, start Group Hole tool and to confirm the result. No individual elements selection is necessary in CE.
With regards,
Jan
Thanks Jan. I can get it to work by selecting everything but not by adding them individually as shown in the help file example.
Duncan Macdonald said:but not by adding them individually as shown in the help file example
Is it e.g. model specific? Because when I try it (to select 2nd hole with Ctrl), it works.
Attached video shows what happens. I'm pressing Ctrl after the first hole is selected.https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/273/Recording-_2300_2.mp4
Why Element Selection is activated when Group Hole tool is finished? Are your user preferences set in some specific way? Group Hole to should remain active (asks for another element) by default.
