In Connect U12 the group hole command doesn't seem to be working. I select the boundary and then the first hole then when I try and hold down Ctrl and pick the next hole it doesn't allow me to select anything.
Are all the shapes on the same plane, any message in the Message Center
I don't know. I've used Group Hole previous to U12 with normal behaviour. My preferences are the default. This happened to one of my users so then I tried it and had the same result.
2d drawing from 2d seed. No messages.
test8.dgnThis is the test file I'm using.
Duncan Macdonald said:This is the test file I'm using.
No problem with the file, should be something with your configuration / workspace.
Jan
