The toggle for online versus local help seems to be a User Preference. Is there a configuration variable that can also control this behavior?
Tried a search in the Configuration Variables dialog but couldn't see anything.
Tried recording a macro and had a look at the VB code for this and there does not appear to be a configuration variable defined for this.
You could raise a new Service Request to log an Enhancement.
Private Sub IModalDialogEvents_OnDialogOpened(ByVal DialogBoxName As String, DialogResult As MsdDialogBoxResult) If DialogBoxName = "Preferences [Personal]" Then ' Set a variable associated with a dialog box SetCExpressionValue "savePrefs.flags.useOnlineHelp", 1, "USERPREF" ' Remove the following line to let the user close the dialog box. DialogResult = msdDialogBoxResultOK End If ' Preferences [Personal] End Sub
Thanks Andrew an enhancement for that would be nice. We tried using %undef MS_HELPLOAD_USEBROWSER so that it would use the local CHM help but that cause no help to open. I am thinking this would be a defect. You may also want to add a defect on OpenRoads as the same user preference did nothing in OpenRoads. OpenRoads always seems to look online for its help. We used %undef MS_HELPLOAD_USEBROWSER in OpenRoads and it opened the local CHM regardless of the user setting. I know its not an OpenRoads forum and I should post this there but... This is all tested in the latest builds on the product.
~HTH
John.
yep
