Really Bentley, are you just changing things for change's sake?
Whenever I press an accudraw shortcut I am used to seeing a little green text text pop-up with a black background confirming the command so where has this gone?
It's a bit disconcerting not seeing this any more so why was this feature removed??
For those not aware of what I am referring to:
Add a few others to that as well Barry. Can't see the point of the space bar or P and M change either. JMO.
Hi Barry,
The Accudraw setting pop up confirmations seems to be removed from CONNECT, only available in V8i.
I will confirm if this functionality was removed on purpose.
Maria Garcia
Hello Barry,
There is a defect #894450 already logged about this.
Regards,Anu
Hello AnuKuu & Maria
Thanks for the update.
Is this likely to be fixed for Update 13?
Barry Lothian said:It's a bit disconcerting not seeing this any more so why was this feature removed??
Previously shortcuts were "part of" AccuDraw and only worked when AccuDraw had focus. The entire shortcut system was enhanced to allow shortcuts to be used regardless of whether the AccuDraw dialog is open. Being able to use shortcuts when focus is either on AccuDraw or Home is probably my favorite change in Connect.
You do still get a popup to help with completing 2 letter shortcuts, but it's at the cursor because shortcuts aren't tied to AccuDraw any longer. A pop-up for single letter shortcuts wasn't considered necessary, especially one that probably isn't where you are looking, but maybe that will be revisited based on the defect that has been filed.
Bear said:Add a few others to that as well Barry. Can't see the point of the space bar or P and M change either. JMO.
If you don't find the spacebar menu useful, just type "keyboard shortcuts" in the ribbon search bar and change the space, P, and M shortcuts to the key-ins you are accustomed to.
HTH
