Does the Analyze > Reports function support nested array type output? For example, when Location Type is a folder path, currently it doesn't seem to list out all References per Model per DGN File. Similarly, it doesn't work if I want to extract all vertices per Line element per DGN file, either. Any advice?
Huan Ting Chen said: it doesn't work if I want to extract all vertices per Line element
Perhaps this article about Linear Reports helps?
Thanks Jon. The Segments.All property is helpful. However, I can't seem to work around listing all References per Model per DGN File. Do you think there's a way?
Hi Huan,
Please use relationship between reference and file. For example,
This after setting this relationship, use appropriate columns to see the result.
As per your rquirement you can choose related items. I have set Design Model & Sheet Model. It lists all (Design and Sheet) models from dgn along with its references. If you need you can add Drawing Model as well.
Mayuri
Hi Mayuri Dengale
Unfortunately it still doesn't work after I add related items. Were you be able to successfully retrieve all references from all files when the Location Type is a folder path?
Happened to figure this out today after three months. The solution is to add "Models" to Item Types and then add "References" to Related Items. That should do it. Cheers.
Answer Verified By: Huan Ting Chen
