Hi All,
I'm trying to label a line string with elevations at each point within the string. The 'Label Element Coordinates' tool is good but labels easting northing and elevation so was wondering if there was a way to not include the easting and northing?
Thanks in advance,
Mark
YOu could create a cell that has place holder cell properties of the origin z. Do this;
Place text
Insert Field
Placeholder Cell Properties
Choose Origin
Select Coordinates Z
Set any other of the formatting you desire
Click OK
Place the Text on the screen
Create a cell containing the text.
Now place the cell it should pick up the Z of the cell. So anything you snap the cell too will give you the Z.
Let me know if this helps.
~HTH
John.
yep
In addition to John's suggestion you could also create a Text Favorite to pick up the Element Property required and place this, the following wiki's should be of help in this regard.
https://communities.bentley.com/products/microstation/w/microstation__wiki/30272/how-to-create-a-text-favorite
https://communities.bentley.com/products/microstation/w/microstation__wiki/36038/how-to-place-a-text-favorite-and-use-the-selected-element-properties
Carl Myhill
Technical Support Engineer
Bentley Systems
Hi Guys,
Thanks for getting back to me. Sorry to waste your time but i have literally just figured it out. What i did was highlight the line strings i wanted to label, click on 'Label Element Co-ordinates', open the 'Key-in' tool. Type in 'label element hidexy on', click on 'Single' and it should do it.
Answer Verified By: Mark Walls
One gotcha with this is that you must pick an element. I first thought to just use a text favorite but couldn't figure out a way to get it to get the coordinate of the text I was placing. Doing it as a Cell allows you to get the location/data point from the cells placement.
Nice find, I wasn't aware of the hide options.
