bonjour
y a t'il une possibilité de manipuler des fichiers en référence?
je dois dropper des cellules et noeud de texte sur 47 fichiers ! Au lieu de le faire 47 fois j'ai mis dans un fichier vierge mes 47 fichiers en référence pour pouvoir décomposer les éléments en 1 seule fois ?
est ce possible ? y a t'il une spécification le permettant ?
Merci par avance pour vos contributions
Cordialement
Microstation V8i select4 win10 x64
You may get more help in the french language forum. However if I understand correctly you want to drop cells and text nodes in 47 reference files. The only way I know to do that is to run a batch process on the files. You would need to find the keyins needed to do this and then create a command file that runs the keyins on each file.
open one file start the vba recorderSelect all cells from power selector go to drop tools and drop cells to geometry.
Go back to powerselector select all text nodes go to drop tools and choose complex on and text on and data point once and escape.
Stop the recorder
open new file run the macro you recorded. no observe it works if ok then open batch processor add all your files now as the macro should still be resident just use the run macro command in the batch processor command text... and it will run the macro over all the listed files...
Lorys
Thank's Lorys
mais le VBA je ne maîtrise pas ! Pouvez-vous me donner une procédure pas à pas ?
L@urent
thanks DuncanHow do you do a batch process! I am not expert enough to carry out such a procedure without an example step by step!if you have a complete procedure I am takerL@urent
https://www.youtube.com/watch?v=ulPVOWTqUeQ
Have a look at this for the basic idea. where he puts keyins to change the level you will need keyins to do what you want to do.
