In MicroStation CE 10.10.00.23, I would fill data fields from cells. I use Fill in Single Enter Data Field tool, then type in text in Value field. I would like to know if I could make the fraction stack. Thank you.
This would really depend on the type of font you are using for this text. This looks like it may be an old RSC type font which probably does not contain stacked type of fractions. Maybe you could supply further details about the font being used and an example design file.
data field test.dgn
Andrew,
The attachment is the sample file upon your request. The font name is ENGINEERING. Fraction does stack when placing text with text editor (text style has Fraction on). It also stacks when using the Fill in Single Enter Data Field tool to edit text in MicroStation V8i with same text style setting. In this case, I believe the font should be fine. I am just wondering if the Fill in Single Enter Data Field tool works differently in MicroStation CE or maybe it's a bug.
Thank you,
Shuling
I have the same issue with the modify data field tool. Has a solution been found?
It would probably be better for you to post your issue as a separate post as it may be a different issue. Also, for any investigation we would require details of the software and version you are using. You might also like to supply example files, screen captures etc. to assist with any investigation.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
My issue is the same as his with the same version and font, word for word, but I will make a new forum post anyways. It works in V8i and not the Connect Edition.
