just updated to windows 10, microstation connect editions text editor background color is white, cant see text as its entered...does anyone know the fix?
Hi Joshua,
Have you selected the color B from the color table? This sentence is in MicroStation Help: "The view background color is in the lower right corner of the toolbox, denoted by "B." So please try some other color, does it become visible?
See also this discussion thread: https://communities.bentley.com/products/microstation/f/microstation-forum/136640/connect-edition-update-5-text-editor-issue/413736#413736
I hope this helps.
Regards,Anu
the fix was buried in a system variable...
Which one?
If you found the solution, please tell us. That will help the next person who comes along with the same problem.
MaryB
Hi MaryB,
Setting configuration variable QV_DISABLE_D3D11=1 can resolve this issue.
With ORD 2020 R1, setting QV_DISABLE_D3D11 variable to 1, will in fact disable your Graphic Card and all graphic will be processed with Software Graphic. This is because ORD 2020 is based on Microstation CE Update 13 and it will not support DirectX9.
