Hi There
I want to change display order of elements in a 3D model but i cannot find a way except changing Z value!!
so because my map is in 3d and all the objects have Z value its impossible to change Z ,so is there any way to turn off this displaying order? or any other solution?
I have a municipal map for example trees or street curbs are displing under a filled shape
Ehsan,
I presume that you want the tree linework to 'overprint' the fill or texture.
I would try referencing your 3d model into a 2d Drawing/Sheet model and see if you can control the sequencing of how the elements are displayed.
1. Ref attachment Update Sequence - as mentioned below, you may have to re-attach the file with only the fill/texture.
2. Display Priority. I think that this should also work.
3. Display Rules... ?
