I recently had an update for the connection client for Bentley products. since the update I had an error message pop up every time PowerDraft is opened. However the error does not display when PowerInroads is opened... Neither software is the connect edition, isthere way to undo the update so I can test to see if that is what is causing the issue?
thanks
Hi Daniel,
Could you please explain what is the error message you are getting?
Maria Garcia
this is the dialog box...
under details this is what pops first:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> Bentley.MicroStation.Exceptions.CommandTableException: Keyin "CONNECTAdvisor CONTEXTUAL START" not mapped to method in AddIn CONNECTAdvisor.CONNECTAdvisorMain at Bentley.Internal.MicroStation.CommandTables.RegisterCommandNumbers(KeyinTree tree, AddIn app) at Bentley.Internal.MicroStation.CommandTables.LoadKeyinTables(String xmlFileName, AddIn app) at Bentley.MicroStation.AddIn.Initialize(IntPtr mdlDescriptor, String appXmlFileFqn) at Bentley.MicroStation.AddIn..ctor(IntPtr mdlDescriptor) at CONNECTAdvisor.CONNECTAdvisorMain..ctor(IntPtr mdlDescIn) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeConstructor(Object[] args, SignatureStruct& signature, IntPtr declaringType) at System.RuntimeMethodHandle.InvokeConstructor(Object[] args, SignatureStruct signature, RuntimeTypeHandle declaringType) at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at Bentley.MicroStation.AddIn.Load(String[] commandTail, IntPtr mdlDesc)
it does not show up in PowerInroads or the Version of MicroStation that we have... Only PowerDraft, and it is with any file that opens
Looks like PowerDraft launching is causing CONNECT Advisor to try and load. Do you have the latest version of both CONNECTION Client and CONNECT Advisor? What version of MIcroStation? I think versions AFTER V8i SS3 will also try and launch CONNECT Advisor..
I have the most up to date Connection Client and Advisor.... Our MicroStation is the V8i SS3...
Daniel Yeagle said:Our MicroStation is the V8i SS3...
Latest version is MicroStation V8i SS4, certified for Windows 10.
