Hi
I've created a parametric cell and placed it in a level in the cell library but when placing this it adopts the active level. Thats not the case for my regular cells, which gets the level it has in it's library. Is there something I can do about this?
I also try to create an icon in the ribbon for some of these cells. Is there a key-in for setting a parametric cell as active without bringing up the dialog for placing a normal cell? Eather by active it in the dark, or get the dialog for interactive cells instead?
Robert
I agree this is to absurd for words ….
Luc Dierick
Belgium
Hi Robert,I had a similar question a few weeks ago, but did not get much feeback on it.
But I put up an idea on which you could vote, if you want to. When enough people vote for an idea the support team will look if they can make it a new software feature.
Here is the link to the idea:
https://communities.bentley.com/products/microstation/i/drafting_and_detailing/parametric-cells-with-lines-on-different-levels
And here is the link to my original thread with a similar question: Parametric cells with lines on different levels
https://communities.bentley.com/products/microstation/f/microstation-forum/175922/parametric-cells-with-lines-on-different-levels---why-do-they-behave-different-than-normal-cells
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
