Dgnlib file
MicroStation Select Series 10 V8i
In .dgnlib there is a level 0 and show not used. will not delete in looking further Using properties the Usage tab shows type Shared Cell Def Id REV_1_1  I tried the file compress, after that closed and re-opened
same problem. I am out of what to do BTW this was a level 56 I could not delete so I made Level 0 and remapped then deleted Level 0
Parents Reply
  • Andrew Bell
    did not understand what are the lines. I was not sure
    so Key-in delete scdefs named seemed to clear the problem. I then Key-in delete scdefs anonymous
    then did Key-in delete scdefs all just in case I needed to
    Use the Key-in: DELETE SCDEFS NAMED|ANONYMOUS|ALL
    Again problem was solved and thank you so very much taking time to respond.
    Version: MicroStation V8i SS 10
    RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
