Need help working from home with your Bentley software? We're here to help - click here
[V8i SS4] Dimensions - Filled Arrowheads vs Notes
Is there a reason why filled arrowheads for dimensions do not mask the dimension line as they do in notes?
I personally dislike the visual appearance of the dimension and would very much like it to match how notes appear
Issue is also found in CONNECT update 12
