Hi all,
Im having problems with the speed of the select duplicates function of Data Cleanup in Microstation CE Update 12 - it seems to select elements much much slower than v8i and eventually gets slower and slower once the selection set gets into the thousands (v8i doesn't have this issue and looks to be substantially faster 10s - see videos below for same data set (I gave up on CE after 2mins).
Is this something only happening to me? I am seeing similar behaviour scanning and selecting a large amount of elements using vba.
CE Update 12
v8i SS4
Sample data set is here if anyone wants to have a look:
1832.test1.dgn
Mark
Defect 1024680 has been filed to address.
Thanks for reporting
Carl Myhill
Technical Support Engineer
Bentley Systems
