As the title.
Open a DWG file in the level display dialog select all off, then select all on. Nothing gets turned back on. The only way to get the level back on is to make it current or select it in level manager and turn display on in the properties.
I'm betting it's the same issue as this:
https://communities.bentley.com/products/microstation/f/microstation-forum/173303/connect-level-global-display-bug
Mark
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
Hi Mark. I think you are right. I have a dgnlib for the level names as part of our set up.
