Hello everyone,
I have this annoying problem: when I open a file and then close it, the file is sort of updated, even if no changes are applied at the file.
I have the option "Auto-Save Design Changes" DISABLED.
I just open the file, than close it, the "Save changes to:" popup windows appear and I answer NO, then the file is updated.
It does not happen if I reopen I file already opened and "updated" as above.
I'm on MicroStation Connect Edition Update 8, Version 10.08.00.37
As I recall, MicroStation has always done that unless files were explicitly opened as "Read Only".But I only have a couple of workspaces where I've ever wanted the Auto-save disabled, so I could be thinking of something else.
Does it change the date if the file IS opened as read-only? if not, that could be your workaround.
MaryB
Thanks for the quick reply.
Yes, if the file is opened read-only the problem doesn't occur.
Not the best solution from a practical standpoint, since i cannot open any file directly from Windows with a double-click.
Or am I missing something?
Mario Tosques said:i cannot open any file directly from Windows with a double-click
If you understand how Windows file associations work, you can tell MicroStation to always open read-only when you double-click in Windows Explorer.
When you install a product, such as MicroStation, the installer adds a file association to Windows. Windows associates the file extension .dgn with executable MicroStation.exe. Windows subsequently sees a file having a .dgn extension and knows to start MicroStation. You can modify the association to include the MicroStation read-only switch.
.dgn
Of course, that means that all files you open with a double-click will be read-only. That may not be what you (or your colleagues) expect. An alternative would be to create a shortcut to MicroStation, and edit the shortcut to include the read-only command-line switch. When you want to open a file read-only, double-click that shortcut and navigate to the file you want to open read-only.
Another alternative for you is to install Bentley View and when you open thru windows explorer use the open with Bentely view , via the shift rmb open with > Bentley view, and it will open as read only and no changes to dates, as your a subscriber to Bentley, then the viewer is FREE...
if you have custom rsc and linestyles etc you'll need to copy them into Bentley views folder
Lorys
Ok, I understand there is not real solution to the bug. Because this is a bug.
As a workaround, I prefer using Bentley View as the default program (as Lorys suggests), and using Microstation on purpose only when I need to edit the file.
Adding the -R option to the command also works. But making it the default behavior of Microstation seems overkill. The shortcut solution is similar to using Bentley View.
Thanks.
I read the OP and was a bit confused. Perhaps lack of knowledge on my part. I had this issue when I started using the bug-ridden Connect. But it was because I needed to add each opened file to a Workset. I use file date for info, so I ran a batch file to add all main DGNs to the appropriate workset. Now when I just open a file the date does not change. The other thing that confused me was that you're getting a 'Save Changes To' prompt. I never see that, likely because I have Auto-Save Design Changes on. Being a long time Microstation user, I don't understand why you'd want that disabled, but there must be a reason. We do have undo.
Hi Mario,
You could create a new shortcut that opens MicroStation in read-only mode in the right-click "Send To" menu of Windows Explorer. This won't change the default DGN double-click behavior, but it will let you easily open any DGN in read-only mode by right-clicking it and choosing Send To> MicroStation (Read-Only).
Now you should be able to right-click on any DGN and pick the MicroStation (Read-Only) shortcut to open the DGN in MicroStation in read-only mode.
Regards,Ron
