This was mentioned in another thread and seems to have been very quietly slipped out
https://www.bentley.com/en/about-us/news/2019/may/01/product-announcement-microstation-v8i-selectseries-10-now-available
Intellitrim is not there. The help says it's been removed. I can't see a keying for Dimension stroke, but I don't use that so if you have the exact keyin I can check.
Intellitrim is not present in Powerdraft SS4 German, too.
Dimension key-in's
DIMENSION SIZE STROKE
DIMENSION SIZE ARROW
Duncan Macdonald said:Intellitrim is not there. The help says it's been removed.
It says that in the SS4 help too but you can also see that it quite clearly hasn't been (see active dialog box)
Could you test the following to see if it still works in SS10?
TRIM QUICK CUT
If all the above does work then I will likely install it, if not then there's probably no point in me doing so.
I fail to see the logic in replacing a tool with a version which provides less functionality than the one it replaces. So many tools still exist hidden under the hood accessible by key-ins, I don't know why Bentley didn't do the same with Intellitrim for CONNECT edition, its not like the code is going to bloat the installer.
Dimension size stroke keyin is there
Dimension size arrow keyin is there
No intellitrim
Dont trust the key-in box...
