is there way to show also the level of selected elements in ref file? so far, when the ref file element is selected all the other parameters are shown (Element type, color, weight, linetype, ... ) but not the level. in fact, no ref file levels are shown in levels tab of Element section dialog.
is this WAD? can it be changed then?thanks
Working for me. This element is in a reference.
Element information, or the Element Selection Tool settings dialog? As far as I can remember, the Element Selection Tool Settings hasn't/doesn't show reference levels (even when a reference element is selected) and so far I have not found a way to change that. I can understand that I might not always want to see them (that could be a looooong list of levels!) but it might be nice if there were some switch or setting to allow that.
MaryB
I think my main question would be the same as MaryB, is this relating to the Element Selection or Element Information tool. What Duncan Macdonald is correct but you can also display whether an element selected in the Element Selection tool comes from a Reference level.
Andrew,
I mean Element Selection tool, so your image is right. anyway, it does not work in my case. I'm also not able to select ref file level in this dialog - these levels are not displayed at all. to be precise, the levels not included in my dgnlib (it means created in ref file only and not existing in master DGN or in DGNLIB file) are not listed in Element Selection dialog.
/pt
