Hi, would I be correct in thinking there is a problem with Accusnap accuracy?
Apologies for starting a new discussion on this subject, but I had been using version 10.04.00.49 ok, and now I have version 10.12.00.42 and I'm experiencing a very wayward Accusnap, i.e. zero accuracy.
I did follow the advice to max out the accuracy settings, but it's still very much hit or miss.
Any advice/guidance would be very much appreciated.
Cheers, Andrew
Are you using Windows 10 with 4k monitor or Windows 10 with high resolution and DPI more than 125%?
We are aware of an issue here and working with Microsoft on getting fixed.
If nothing of above, then is it possible to share a little more information like, DGN File, System Details, a short Video, etc?
Hi Sumit, it seems to be Windows 10 'Scale and layout' percentage. I'm on a laptop using a second basic screen, the second screen being set at 100%, but the laptop was set at 150%. Since setting both monitors at 100% all seems fine. Phew! :-)
