Hey all It would be great to be able to import alignment Landxml file to microstation "CONNECT".Landxml Terrain model can already be imported so why not add alignment Landxml file support as well. Would be good for us who are reviewing project planning.Best RegardsTom
http://www.landxml.org/schema/LandXML-1.2/documentation/LandXML-1.2Doc.html
Lillhannus said:It would be great to be able to import alignment Landxml file to microstation "CONNECT"
Post that suggestion to the Ideas Forum!
OpenRoads already has the ability to do this.
Timothy Hickman
Main: 877 627 3772|
Hello I was afraid to get an answer you gave! Open roads, open rail so on and so on, but as a reviewer you only have access to basic programs, in this case only standard microstation. The information that is projected in different software in different platforms can usually supply LandXML information. So it would be an advantage to be able to review project information with standard Microstation platform without applications. We, as reviewers, do not project, we are employed by the client of the project to see if the design is buildable
Continued ... This is why functions such as loading XMLTerrain models and Alignment Xml files are so important to be able to read in for control so the information in the delivery is right. We / I do not design and do not need to own an expensive planning program just to review the design
