accudraw not orthagonal. Not sure what I have done but accudraw is not at 90degrees to my screen when we start to draw a line. it is so slightly out. I have to press 'v' each command to get accudraw to be orthagonal
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
connect edition 10.05.00.49
Have you checked the AcuuDraw Settings? Maybe something has changed there?
/Krister
Owner consultant at Surell Consulting AB
Check that the Accudraw settings -> coordinate system is set to View.
MaryB
Could be your ACS has rotated which I find happens occasionally (more so in 3D than 2D). Bring up the ACS dialog, select the active view and reset it as per below.
Then press T (with accudraw highlighted) and it should return back to normal.
