I just switched over to Microstation Connect Edition from V8I. In V8I I used to be able to set my references as elements for manipulation and copy them from one file and paste them into another file. This doesn't seem to work in Connect Edition. Is there a solution to this?
This is still not working as of Connect Edition update 14 v. 10.14.02.01
Defect 1118599 has been raised for Development review, if you wish to be updated then please raise a Service Request and ask for it to be logged against this. Thank you.
