Microstation Connect Edition, Update 12
I have created a Display Style with the following conditions:
- Element is Shape
- Element is color = 2
When theese conditions are met and the Display Style is used, the element has to be shown with a pattern inside the shape.This I have configured via the Actions and the pattern I use is taken from a cell library.
Here is my issue.
If I draw a shape element with the color = 2 and apply the Display Style, the shape element is displayed as wished.But if I attach a reference file where there is a shape element with color = 2 and apply the Display Style, the element will not be shown with cell pattern inside. why is this..??
Hope someone has some advise.
The rule is inside the second DGN? If so that don't work as the element is now from a reference, so you'll have to redo the rule accordingly.
José
Thanks for feedback..
I of course forgot to mention that the Display style I created has been created in a DgnLib, which is part of my workspace for all files I’m working with..
This is an issue with Display Rules. Defect has been filed for the same Issue. Defect# 1030280
Amruth
I have created a new service request: SrvReqNo:[7000919232] as I coundn't find and follow the one defect# 1030280 provided by Amruth GL.
You would not have access to see this defect so I have linked your Service Request to it within our systems.
