hello, I have a question regarding the ability to change the function of keys within MicroStation.
mainly I would like the "Enter" key to complete my action.
For example: when I click the screen to insert a line, I would like to type the length and angle and finish the command with the "Enter" key.
is this possible?
thank you
Unlikely, AutoCad user huh? you'll need 2 hands for Microstation. If you enter the length and distance with a key-in like di=100,90, enter will complete the command.
Perhaps someone knows how to make it complete with enter.
Accudraw allows you to enter distance and angle. Enter will finish the command.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
You'll also need two hands for Autocad. If not you can always take away your hand from the mouse and press the desired key from the keyboard.
And there's also the virtual keyboards for those who like only to use the mouse.
José
Is that new in Connect? In V8i, when I place a line I can enter distance and angle, and <Enter> will lock in those distances, but I still need the left mouse click to place that data point.
MaryB
Nope, it does not do this. I was mistaking. You are correct Mary, a data point is required
