how can i put text on 3d object and keep it attch to that object so if i rotate the view it will stay on the top of the object?
Have you tried View Independent Text? How does that behave?
MaryB
Answer Verified By: lina obeidat
YES IT WORKING NOW
THANKS
i have trouble changing the test properties like text height it does not allow me to change it
Which version of MicroStation? Are you using a Text Style? Have you tried the Change Text Attributes tool?
https://communities.bentley.com/products/microstation/w/microstation__wiki/13264/quick-way-of-matching-element-attribute?CommentId=2a7b1249-e0f3-4cdd-9a10-c761ee829367
