When publishing an I-model in Microstation CONNECT (10.11.00.36), I am only able to obtain a ver 1.6 i.dgn file. This is not recognised by my Navigator CONNECT (06.01.06.10) programme. Is a separate plug-in required to publish .imodel files from Microstation?
My understanding was that in MicroStation CONNECT Edition (Update 11) the pulldown menu next to the option to create a .imodel would contain the list of versions 1.6 & 2.0.
https://communities.bentley.com/products/microstation/w/microstation__wiki/34517/introduction-to-publishing-i-models-from-microstation
https://communities.bentley.com/products/microstation/w/microstation__wiki/34803/publishing-compatible-i-model-s-from-microstation
Steven Smith said:I am only able to obtain a ver 1.6 i.dgn file
Select option Create an iModel version and choose the version in the adjacent menu.
Hi Andrew, Jon,
Thanks for your responses. Unfortunately, the drop down only gives me the option to publish a 1.6 version file. There is no .imodel option available.
Steven Smith said: the drop down only gives me the option to publish a 1.6 version file.
There's a version table in the second link provided by Andrew. It tells us that v2 iModel export became available with MicroStation CONNECT Update 11.
Thanks Jon, I appear to have the latest version installed but the available output formats do not correspond with that shown in the versions table. Perhaps an issue specific to my software installation.
