I’ve just had Windows 10 loaded as my operating system and after reloading Microstation Connect 10.11.00.36 I have lost the view task bar icons.
When Microstation loads up I get the below msg.
I have tried uninstalling then reinstalling Microstation Connect.
Any ideas how to fix this?
Hi William,
You can try to RMB (right mouse button) on top this bar to see if the icons are simply turned off. I know that at least one as to be on. So probably this is not it.
One way is for you to check if you have the latest graphic drivers for you graphic card.
If yes then your graphic card is old and you should use an older driver.
If this not it, another help is to make CE use DirectX9 instead of 10 or 11 to see if it helps:
For that go to Backstage\Settings\Configuration\Configuration Variables:
Write: 11, choose QV_DISABLE_D3D11 then Select then OK. Restart Microstation and check if it ok.
Get some help here.
José
Please review the following wiki article https://communities.bentley.com/products/microstation/w/microstation__wiki/10583/error---unable-to-load-create-dialog-item-of-type-iconcmd-id
Check if there is any conflict between delivered menus and maybe customized menus
and let us know if any of the recommended options resolves the issue.
Maria
What was the OS prior to the change ? When it was loaded, were the video cards updated ? how about the video card drivers ?
Are you using a custom configuration ? if so - what happens if this is not used ?
Have you tried setting the variable that Jose mentioned ?
Timothy Hickman
Main: 877 627 3772|
I have exact same problem
Icons disappears only when I load a 3D model. On a 2D Model I do not have this problem
I also have MicroStation V8i (SS4) and MicroStation Connect (Update 12) on same computer with Windows 10 (1809)
I do not have any customization. My drivers are up to date and I don't know why I should use direct X9 instead of directx 11
Remy
